Need Help with FPP Channels
pb4ugoout
Hello!
New here. I'm so close to having this all working and I've hit a stumbling block. I've got 2 trees, 4 flakes, 3 candy canes, and some icicles. All lights work. I've got a simple animation setup in xLights and I can play it from xLights without issue. The animation plays perfectly. This tells me that I have my controller configured correctly. It's an Alphapix Classic 16. I know I know. Please don't tell me I should have done something else. Like I said, it all works. My problem is in FPP. I'm sure it's just a configuration goof on my part, but when I play the show from FPP the lights work, they just aren't outputting the show correctly. It's like my universe/channel config in FPP is wrong. The manual isn't super clear on what all that stuff should be so I guessed based on my Alphapix config and my layout in xLights. I'm hoping someone can point me in the right direction. Anyone have thoughts? This is the final piece for me getting this thing working. I tried to get it going in xSchedule on my computer but I think the crappy wifi-to-eth bridge I was using at the controller is a bottleneck because the animation would flash and stutter. I've attached shots of my layout in xlights, my config from the alphapix, and my config from FPP.
Thanks in advance!
G'day pb4, you only need one line in the configuration for output in the FPP. Start channel is 1, start universe is one and you have 11x universes.
Cheers Bazzy
