smeighan
New Release, 3.0.16. Countdown timer.
I have added a countdown timer checkbox in the Text effect
Here is how this works
1) Put whole integer numbers as either line 1 or line 2 in the text.
2) Click the "Countdown Timer?" check box
Press play.
Timer will start with the number you entered and count down to zero.
NUTCRACKER RELEASES
3.0.16: Jun 28,2013 - New option added to the Text effect, Countdown timer.
3.0.15: Jun 27,2013 - Added check to make it so empty picture selection does not cause hundreds of pop up windows
- fixed LOR lms and lcb export
- added check to make sure model's have at least 1 pixel wide and high
- new feature in Meteors effect. Meteors can now fall up
sean
Press play.
NUTCRACKER RELEASES
sean
