smeighan
bars can now so some new things
sparkles , 3 types
Random Rainbow
White
Same Hue
You can now get vertical bars besides horizontal.
Lets start with a horizontal bar effect with no sparkles. I have BOLD marked the new prompts
bars Effect Settings
username f
user_target A
effect_class bars
effect_name BARS_VERT1
window_degrees 180
frame_delay 100
number_bars 6
bar_type H
sparkle_type S
sparkles 0
fade_3d Y
speed 1
direction down
color1 #FF0000
color2 #FF8E0D
color3 #FFFF00
color4 #2BFF00
color5 #006FFF
color6 #4C00FF
highlight Y
seq_duration 4.857255
fade_in 0
fade_out 0
submit Submit Form to create your effect
OBJECT_NAME bars
batch 0
First we will try "Same Hue" sparkle_type with sparkles percentage at 50%
Now we will try the Rainbow Hue sparkles.
Since sparkles override the rgb values of the colors you select you can do something like make your colors dark.
username f
user_target A
effect_class bars
effect_name BARS_VERT3
window_degrees 180
frame_delay 100
number_bars 2
bar_type H
sparkle_type R
sparkles 50
fade_3d Y
speed 1
direction down
color1 #00006B
color2 #00006B
color3 #00006B
color4 #00006B
color5 #00006B
color6 #00006B
highlight Y
fade_in 0
fade_out 0
OBJECT_NAME bars
batch 0
Finally you can select bqr type ='Vertical'
username f
user_target A
effect_class bars
effect_name BARS_VERT4
window_degrees 180
frame_delay 100
number_bars 2
bar_type V
sparkle_type W
sparkles 50
fade_3d Y
speed 1
direction right
color1 #FF0000
color2 #FFF700
color3 #00FF1A
color4 #0800FF
color5 #FF00EE
color6 #FFFFFF
highlight Y
fade_in 0
fade_out 0
OBJECT_NAME bars
batch 0
I will discuss this some tonight in the tutorial.
thanks
sean
sparkles , 3 types
Random Rainbow
White
Same Hue
username f
user_target A
effect_class bars
window_degrees 180
frame_delay 100
number_bars 6
bar_type H
sparkle_type S
sparkles 0
fade_3d Y
speed 1
direction down
color1 #FF0000
color2 #FF8E0D
color3 #FFFF00
color4 #2BFF00
color5 #006FFF
color6 #4C00FF
highlight Y
fade_in 0
fade_out 0
OBJECT_NAME bars
batch 0
username f
user_target A
effect_class bars
window_degrees 180
frame_delay 100
number_bars 2
bar_type H
sparkle_type R
sparkles 50
fade_3d Y
speed 1
direction down
color1 #00006B
color2 #00006B
color3 #00006B
color4 #00006B
color5 #00006B
color6 #00006B
highlight Y
fade_in 0
fade_out 0
OBJECT_NAME bars
batch 0
username f
user_target A
effect_class bars
window_degrees 180
frame_delay 100
number_bars 2
bar_type V
sparkle_type W
sparkles 50
fade_3d Y
speed 1
direction right
color1 #FF0000
color2 #FFF700
color3 #00FF1A
color4 #0800FF
color5 #FF00EE
color6 #FFFFFF
highlight Y
fade_in 0
fade_out 0
OBJECT_NAME bars
batch 0
thanks
sean
