smeighan
A user contacted me with a problem he was having trying to layer a gif with the fire effect.
Long story short
1) Animated gifs cannot be used in layers, you should be using pictures
2) Oops, i hadnt finished the Pictures effect class. It is now done
3) I enhanced this effect so you can pick gif,png or jpg files
4) Each picture can be moved up,down,left,right,none. None means your picture will be stationary
5) New option for changing speed. I will retrofit most effects with speed. Speed=1 means each frame animation moves one pixel.
speed=.5, animation is twice as slow, speed=3, 3 times faster. Start with 1.0 and then play
So how does it work? Select the pictures class. Upload some images and then create effects.
So, first i will show that i solved the original problem. I must give credit to user phar for coming up with the idea to use the pirate image to overlay the fire.
Here is a fire effect on a matrix target
Here is a static gif (direction=none). NOTE: gifs in the picture class are different than animated gifs in the gif class. Gifs are ok here as long as they are not animated
Here is original gif
and what it looks like when projected onto matrix
and here is the layer between the two. Use the Skull and bones as a mask against the fire
what about the speed and direction options?
i will use this fractal for these tests:
first test
direction = left, speed=1
second test
direction=down, speed=1
third test
direction=down, speed=2
enjoy pictures!
sean
Long story short
first test
second test
third test
enjoy pictures!
sean
