Nutcracker: Please check your frame delay values
smeighan
4217 Greenfinch Dr CO 80126
meighan.net was at 22 gigbytes out of the 25 gbyte limit for my account.
In looking at effects in the database, I cam across a user who set frame_delay to 1. This means 1ms.
His 5 second animation produced 5000 dat files and used alot of disk space.
No one should have frame timing of 1 ms. In fact, i may have to implement that no one can have frame timing of less than 50ms on meighan.net. If you want shorter times, do a local install.
I will be doing my shows with 100ms timing, maybe 50ms.
On an RGB device where i am creating 7200 channels for my megatree per frame. 100ms to 1 ms means the files produces are 100 times larger.
I have gone thru and changed any effects that had 0, 1, .5 ms timings, i set them to 10ms.
These small timings cannot be what you were expecting.
Please review your timings on effects.
Remember, I am prompting you for frame timing in milliseconds, not centiseconds.
thanks
sean
is it also possable to delete effects ,
i tryed some other peoples an did'nt like them an would like to remove them from my profile if that is possable
thanks
thanks
On the menu bar go to
Admin
Cleanup Old Effects and Models
thanks
