smeighan
There was a request to see if single strand could have 3 colors instead of twp. This person wanted to make Red, White, Blue chase for 4th of July.
I also noticed it you had RWB and then reversed direction with fade 3d, it looked funny because the leading edge of the chase was faded and then went to full intensity. I have fixed this also. Now the leading edge of a chase will always be brightest.
New code is released. Code has been checked in to github.
single_strand Effect Settings
username f
user_target A0_ARCH
effect_class single_strand
effect_name SS_ARCH
frame_delay 100
direction right
speed 1
seq_duration 6.482209
fade_in 1
fade_out 1
OBJECT_NAME single_strand
batch 0
fade_3d N
window_degrees 360
show_frame N
submit Submit Form to create your effects
Single Strand
username f
user_target A0_ARCH
effect_name SS_ARCH
frame_delay 100
direction right
speed 1
fade_in 1
fade_out 1
batch 0
fade_3d N
window_degrees 360
show_frame N
Single Strand
