All
See Bulk Buy Rules for rules on the bulk buy.
Pricing below NOW includes the Paypal Fees which i forgot in the first post, to keep the pricing down the 3% overhead has not been included for this buy as a present from me.
This will close on Monday 13th September at which time i should already have an initial order being assembled, the full order will be placed once payments are received.
We will speed this up as fast as possible for everyone.
For details on this controller see
http://forums.auschristmaslighting.com/index.php/topic,231.0.html
Important info
From the Beta boards to the production boards a small change has been made, the controller now has FOUR separate outputs. This will need a small firmware change once the boards have arrived.
Pricing will be as follows and is provisional on final assembly cost, whilst it is a little higher than indicated in Chat the other day it is hoped still that it may even come down. (all in US Dollars)
Bulk Buy price based on 50 units being ordered
All units will be assembled and fully QA tested to power up, process DMX and Output from both buffered outputs.
No cases supplied with options below as there are many ways for these to be enclosed.
Option1.
TP3212 as a fully assembled Module
This will be QA tested and supplied without cables, this enables you to wire it as per your own requirements.
Provisional Cost: US$37.00
Option2.
TP3212 as a fully assembled Module with full cable set
This will be QA tested and supplied with cables for all inputs and outputs, all cables supplied as male/female pairs so you can wire the connecting equipment as well.
Provisional Cost US$43.50
All cable connectors are o-ring sealed and should provide a nice weatherproof fitting.
Regards
Phil
Important info
Option1.
Option2.
Regards
Phil
