p12R problem.
imblunt
I am having a very annoying problem with my ECG-P12R that I purchased late last year.
I am unable to get it to work properly on either sACN or Artnet. I also have a ECG-P2 and that works fine on Artnet (my preferred protocol to avoid conflicts)
A bit about the setup.
I have the P12R set to 192.168.0.247 and the P2 to 192.168.0.246 both on 255.255.252 subnet. For control I am running an ETC Gio console that is outputting sACN to a Pathport 8 gateway and I have 2 other parthport single universe(port) boxes also running on sACN totalling 4 DMX universes.
The reason I need to use Artnet is because I have a second console an ETC ION that is going to be controlling the LED using Artnet doing pixel mapping with a media server.
I am using WS2811 pixel strips I have 100m worth and will be grouping them in lots of 9. When I have tested this setup with the P2 it works fine over artnet but on the P12R it does not work. When I switch to sACN I get the strips to light up but then flash to full white then back to the programmed level and colour. This occurs over both controllers. I have checked and test mode is off in the webpage and the switch thinking it was that but it still occurs.
I have attached screenshots of the 2 controllers info page. Is it something to do with the app version on the P12R that is causing the problem?
Code:
xml from p12r
<network artnet='1'/>
<string num='1' act='1' type='WS2811' speed='3500' univ='1' slotstart='1' pixcount='60'/>
<string num='2' act='1' type='WS2811' speed='3500' univ='1' slotstart='1' pixcount='60'/>
<string num='3' act='1' type='WS2811' speed='3500' univ='1' slotstart='1' pixcount='60'/>
<string num='4' act='1' type='WS2811' speed='3500' univ='1' slotstart='1' pixcount='60'/>
<string num='5' act='1' type='WS2811' speed='3500' univ='1' slotstart='1' pixcount='60'/>
<string num='6' act='1' type='WS2811' speed='3500' univ='1' slotstart='1' pixcount='60'/>
<string num='7' act='1' type='WS2811' speed='3500' univ='1' slotstart='1' pixcount='60'/>
<string num='8' act='1' type='WS2811' speed='3500' univ='1' slotstart='1' pixcount='60'/>
<string num='9' act='1' type='WS2811' speed='3500' univ='1' slotstart='1' pixcount='60'/>
<string num='10' act='1' type='WS2811' speed='3500' univ='1' slotstart='1' pixcount='60'/>
<string num='11' act='1' type='WS2811' speed='3500' univ='1' slotstart='1' pixcount='60'/>
<string num='12' act='1' type='WS2811' speed='3500' univ='1' slotstart='1' pixcount='60'/>
<effect num='1' suf='A' act='1' pixstart='1' pixcount='60' rgbconv='GRB' null='0' repeat='9'/>
<effect num='2' suf='A' act='1' pixstart='1' pixcount='60' rgbconv='GRB' null='0' repeat='4'/>
<effect num='3' suf='A' act='1' pixstart='1' pixcount='60' rgbconv='GRB' null='0' repeat='4'/>
<effect num='4' suf='A' act='1' pixstart='1' pixcount='60' rgbconv='GRB' null='0' repeat='4'/>
<effect num='5' suf='A' act='1' pixstart='1' pixcount='60' rgbconv='GRB' null='0' repeat='4'/>
<effect num='6' suf='A' act='1' pixstart='1' pixcount='60' rgbconv='GRB' null='0' repeat='4'/>
<effect num='7' suf='A' act='1' pixstart='1' pixcount='60' rgbconv='GRB' null='0' repeat='4'/>
<effect num='8' suf='A' act='1' pixstart='1' pixcount='60' rgbconv='GRB' null='0' repeat='4'/>
<effect num='9' suf='A' act='1' pixstart='1' pixcount='60' rgbconv='GRB' null='0' repeat='4'/>
<effect num='10' suf='A' act='1' pixstart='1' pixcount='60' rgbconv='GRB' null='0' repeat='4'/>
<effect num='11' suf='A' act='1' pixstart='1' pixcount='60' rgbconv='GRB' null='0' repeat='4'/>
<effect num='12' suf='A' act='1' pixstart='1' pixcount='60' rgbconv='GRB' null='0' repeat='4'/>
xml from P2 port
<string num='1' act='1' type='WS2811' speed='3500' univ='1' slotstart='1' pixcount='135'/>
<string num='2' univ='1' slotstart='26' pixcount='55'/>
<string num='3' univ='3' slotstart='1' pixcount='48'/>
<string num='4' univ='4' slotstart='1' pixcount='48'/>
<string num='5' type='WS2811' speed='3500' univ='1' slotstart='1' pixcount='48'/>
<string num='6' univ='2' slotstart='1' pixcount='48'/>
<string num='7' univ='3' slotstart='1' pixcount='48'/>
<effect num='1' suf='A' act='1' pixstart='1' pixcount='135' rgbconv='GRB' null='0' repeat='9'/>
<effect num='1' suf='B' pixstart='25' pixcount='28' rgbconv='GRB' null='0' repeat='9'/>
<effect num='1' suf='C' pixstart='15' pixcount='11' rgbconv='RGB' null='0' repeat='9'/>
<effect num='1' suf='D' pixstart='27' pixcount='1' rgbconv='RGB' null='0' repeat='6'/>
<effect num='2' suf='A' pixstart='25' pixcount='55' rgbconv='GRB' null='0' repeat='9'/>
<effect num='3' suf='A' pixstart='1' pixcount='48' rgbconv='GRB' null='0' repeat='5'/>
<effect num='4' suf='A' pixstart='1' pixcount='48' rgbconv='GRB' null='0' repeat='5'/>
<effect num='5' suf='A' pixstart='1' pixcount='48' rgbconv='GRB' null='0' repeat='5'/>
<effect num='6' suf='A' pixstart='1' pixcount='48' rgbconv='GRB' null='0' repeat='5'/>
<effect num='7' suf='A' pixstart='1' pixcount='48' rgbconv='GRB' null='0' repeat='5'/>
hi imblunt can you do a screen shot of your string config and effects page please. also is it a p12s or a p12r as you say it is a p12r but it looks like it may be a p12s just double checking.
