Yes, pretty safe to assume that. Connectors pin out Its pretty universal too, unless production screw it up here and there.Hi guys,
Seems like a dumb question, but just want to confirm before i wire my pigtails into the controller...
Working out which wire is which, is is safe to assume that the order they go into the pigtail plug is the order they are on the actual plug prongs? e.g. below.
Hope that makes sense.
best to use a digital multimeter to confirm continuity!
On the pixels cords is more easier to gauge, usually the + and - pin goes straight and you can look true the resin. I did not check mines but you can install the pigtail in one end then measure continuity using the other end of the pixel cord.How would you do that with the pins inside the pixel all coated in resin?
Unless you install the pigtails yourself I don't see how you could possibly know without checking continuity on each wire and the wire its connected to on the pigtail. Don't wire V+ to data and you should be good. Pretty sure you will get no continuity on the data wire FYIHow would you do that with the pins inside the pixel all coated in resin?
That's correct, you don't get continuity on data.Pretty sure you will get no continuity on the data wire FYI
