jrk1963
Hi
I am planning to build window frames with 2811 5v pixel nodes. I have figured out the spacing to get everything to come out the way that I want. I have three window frames that will need a total of 348 nodes and a fourth that will use 300 nodes.
I was just looking at the power reference by Fast Eddy. According to my calculations using this reference, the large window frames will need 104.4 watts and 20.88 amps and the smaller one will need 100 watts and 18 amps. The total would be 413.2 watts and 82.64 amps at 5vdc.
I am in the US and we use 120v AC power here. I also have two 5vdc power supplies. These should handle the load.
I am wondering about the wire needed to supply power to the pixels. My initial plan was to use a four conductor waterproof cable and tie two together for the positive and the other two for the negative. I'm not sure, but I think these are 18 gauge stranded wire. In the US it is recommended to use a minimum of 12 gauge solid wire for a 20 amp AC circuit. Will two 18 gauge stranded wires tied together in this manner be enough to handle the load to one window frame?
Also I'm concerned about the AC side of the power supplies. I am familiar with ohms law, but, I am confused regarding 120vac versus 5vdc. If I am pulling 82.64 amps at 5vdc, what would the power draw be on the AC side? Would it still be 82.64 amps, or would it be 3.4 amps?
Thanks.
Jerry
Thanks.
Jerry
