PixelSticks and WLED (DIG QUAD)
Gmick
This is the third year of running an xLight show. Up to now I have been running xLights through the WLED software on the DIg-Quad controllers.
So I have been doing some reading on the Pixelstick software running on the Dig-Quad controllers. I like the idea and would like to look further about setting it up. But, (there is always a but), one of the contrrollers is running my house Eaves lights and I would like to run them throughout the year as just nice lighting and patterns off the WLED app.
Question 1 - Can you combine Pixelstick controllers and WLED controllers together in the XLIGHTS controller section?
Question 2 - Also, I am trying to understand how the complete controller setup works in that if you use pixelsticks, is it still controlled by running the XLIGHTS software i.e. scheduler?
Any good information that I can lookt to fully understand how to setup . This year I have 6 DIGQuad controllers and next year it could double. (after I convince my wife).
Suggestions, comments , useful information?
You can add WLED as a controller in xLights,
On windows you can use xScheduler on your computer but many people prefer to use something called FPP which is on a Raspberry Pi to manage the show playing as it's a dedicated device.
So if WLED is performing fine for you already, I don’t think I’d bother trying to change the firmware.
But if that’s not the case - there’s a few things:
  • ESPixel stick can run as an “FPP Remote” so instead of streaming all show data to it, you upload the files ahead of time and just stream sync packets. Much more efficient over wifi.
  • There’s no way to run both firmwares on a controller at once. You would have to either: just use espixelstick firmware all year, flash it back to WLED in January, have a replacement controller ready to swap out
  • The FPP remote mode requires storage (SD card) on your controller. My Dig-quads don’t have this (and it’s not the default)
  • XLights can mix and match controllers. You can have some from a bunch of different technologies and vendors all working together.
  • If you are looking at seasonal lighting (and not all year round where WLED shines) may find some of the larger controllers better value. Something like the Baldrick8 or even larger to a Falcon or Kulp may work out cheaper/easier than buying a bunch of new dig-quads.
Thank you all for the information. I do run XSchedule on a dedicate cube compter with auto updates tuurned off and it works great . As far as the Controlers go, I was just wondering if using WLED on all of them is going to create a lot of traffic once I expand it next year. I do hve Cat6 connections into each and will be looking at using that next year rather than wifi. The only issue I saw last year was that once in a while, the matrix would hicup. I was running the matrix on a single dig-octa but have changed it to be 2 dig-octas now . (I gave the wrong controllers in the original post. I am running all Dig-octa's) If I have time before december I may look and see if I can run a cat6 cable to the boxes before it gets too cold and the snow flies.
It is good to know that I can mix and match the controllers in xLights, I thought I could but its great to get that confrmation. Getting ready for Halloween show starting on sunday so I will see how things are working with the changes I made to the controllers and then decide what to do ..
Thank you for you help and comments..
how many pixels do you have on the matrix? This is where the dig-octa starts to show its limits - each brain board is limited in how many pixels it can drive. My general rule of thumb is about 2000 pixels (at 40fps) is the limit for WLED on e131 at 40fps. I think DDP would go a little bit higher -- but I was getting lag effects visible on my 2400 pixels (spread across 4 ports)
So it has been interesting. Got it all hooked up and went to watch the show and ugh. Lags. The two controller boxes outside each have two did ovtas in them. The matrix is 2048. It is split across 6 outputs on two controllers for a total of 12 connections. Each controller is handling 1024 lights. So, I hooked up cat 6 to each controller and turned off the wifi. So far, no lags now. Tonight will be the real test on the dark. But it looks like the solution is to not use wifi. The controllers that handled the eves and garage lights are already direct to lan as they are inside. So fingers crossed. Will be interesting to see what happens next year when I add a 4000 pixel matrix, 24 string tree and arches.
RE: Question 1: The ESP32 device does not have the ability to hold two images at the same time. You can load WLED or You can load ESPS V4. You can also easily switch between the two. Both of the applications have web based installers, making it easy to switch.
FYI: EspixelStick has 80% of the same effects that you can find in WLED. The big draw is the ability to reduce the WiFi load (and therefore the lag) by using FPP Remote.
RE Question 2: Yes xLights talks to the ESPS and can play sequences using DDP / FPP Remote or (less optimally) E1.31 / Artnet.
The problem is LAG in WiFI. This is why ESPS V4 supports FPP Remote mode. In this mode, there is almost no data on the WiFi, hence no lag. xLights player also supports sending FPP sync messages instead of data. xLights supports pushing the appropriate sequences to the ESPS devices.
FYI: DDP has less lag than E1.31 but it still has lag.
One last comment: Wired Ethernet also has lag. The lag just happens to be small enough that most of the time you dont notice it.
working/playing around with ESPixelStick software on a DIG-OCTA board. Also got a Raspberry PI V5. Have FPP installed on the Raspberry Pi. So.. when I look at the ESPixelstick software on the DigOcta it only allows for a relay on Output 8. I have that setup to GPIO ID 33, If I set it to Inverted, the blue light on the Relay port lights up. I created a sequence where there is a Model with a single pixel on the sequence. on that model (relay1) I assgned to the ESPixelstick and have the Light ON with full brightness. When I run the sequence through the FPP running on the RaspberryPi, the relay output on the DigOcta does not change. There must be a secret I am not doing but so far I cannot figure out what that is. I want the Relay to control the power to my lights so the power supply is not running inbetween shows. And one last thing, I thought that the ESPixelstick should have some light patterns that you can run.. the lateset version for the DigOcta has none (that I can find) .
