Yea, the only injecting I do is inline. It's less messy and just much more straightforward. Less cabling in the long run.It was just a question I noticed on 101 info sheet there’s two ways to inject inline and multiple psu
Wattage doesn't matter IF the total power (watts) of the lights you are running is less than the total power of the power supplies you have powering them. I would also recommend not running your power supplies at or near full capacity.You can run whatever wattage you want. Wattage doesn’t matter, in my experience. Voltage. Common ground. That’s what’s important.
Yea. True point. Sort of just assumed that was a given.Wattage doesn't matter IF the total power (watts) of the lights you are running is less than the total power of the power supplies you have powering them. I would also recommend not running your power supplies at or near full capacity.
