Power supply to smart receiver
Jon_101
Hi all, is it possible to connect both grounds of power supplies together as shown in the attached photo?
i13
The safest answer is no if you're powering pixels through the pigtails on the left. The on-board fuses are (usually on most controllers) on the positive. For the left-hand power supply, you have bypassed the fuses but the current still flows through the negative trace on the controller in order to complete the circuit.
i13
I should explain how to do this correctly. Connect the negative output of the left-hand power supply to the controller's outputs instead of its input. Add a fuse in each positive wire between the pigtails and the left-hand power supply.
Jon_101
Thanks for your answer, but even if you connect ground after the fuse,
Thanks, I did it your way and its working.
TerryK
Retired Elf
West Central Ohio
The lack of a detail or two prevents a precise answer. Specifically, what is the amperage ability of each supply? What is the amperage demand for each pixel string; at your intended or configured drive level (white)? And a note that if one takes your sketch as it is literally drawn, the placement of the wire splices add ambiguity.
To answer your question without suggestions based on assumptions, I agree with 'bpratt', yes.
