Hi. Has anyone had issues with PPRs working erratically, possibly due to overheating? I'm getting ready for the upcoming season and my testing has had some troubles, and the culprit seems to be my PPR-Bs when they get warm. It's only 13C today, so I didn't expect overheating from such a small unit. Has anyone who uses these in summer climates had any issues with them?
Here's what I observed.
On a side note, has anyone bought anything from J1sys recently? I've reached to them twice now and didn't hear back. Not sure if they are selling product or not.
I hope everyone is getting excited about the upcoming season. I know I am.
Cheers,
Bob
- When testing my strings on the ground outside prior to putting them up, I initially had no issue, but then after some time I started noticing erratic flickers or sporadic incorrect LED colours.
- I noted that the PPR-B on-board LED would start to flicker itself intermittently, and this seemed to coincide with flickers on the strings. The LED indicates +5 going to the board circuitry, so if it goes out, then the board isn't getting it's +5 it needs to run. (I run 24V from the controller and an on-board converter converts to +5 for the board's use.)
- The PPR LED flickering only happens after it's been running a few minutes and it's inside the small container I used to protect it from the elements. When I take the lid off, the flickering stops. Put it back on the flickering resumes after a few minutes. Rinse and repeat consistently.
- I've run these for 2 winters now in the enclosures I'm using, which are 7cm x 7cm x 5cm food containers, with holes for the wiring in and out. Never noticed a problem before, but it's likely that I haven't run them at 13C before - usually I'm later getting set up and it's colder outside.
Cheers,
Bob
