smeighan
PRODUCTION release of xlights 2017.14
2017.14 May 17, 2017
-- enh (gil) Add additional colors to color manager.
-- bug (gil) Fix Align Both Times case that was failing.
-- bug (gil) Fix effect panel not updating icon when using drop-down combo.
-- bug (dkulp) Fix crash if model using #x:y notation has end channel beyond end of setup. Fixes #859
-- bug (dkulp) Fix crash if expand group with submodels and model doesn't exist in sequence
-- bug (dkulp) Hook up the renderDirty event to the align options and undo to render the changes
-- bug (keith) Fix 64 bit stack walking on windows.
-- enh (keith) Allow entering of a description for a FPP instance in the connection dialog
-- enh (keith) Allow bulk uploading of sequences to all known FPP instances
-- enh (keith) Add select used/unused models to Display Elements model list right click menu
-- enh (keith) Add a per node option to candle effect
-- bug (keith) Fix some drag and drop issues in the master view in display elements panel
Thanks Gil, Dan, Keith, Chris for keeping enhancing and fixing our product!
This is the release we will use this weekend.
