Release Release 2017.4. Include latest xSchedule.exe in install
smeighan
4217 Greenfinch Dr CO 80126
Release 2017.4. Some enhancements and a few bugs. Main purpose is to bundle newer version of xSchedule.exe. 2017.3 did not have the latest version.
2017.4 Feb 14, 2017
-- bug (sean) Include latest xSchedule.exe in release. 2017.3 had old version.
-- enh (dkulp) Add a couple "Per Model" render buffer styles to the ModelGroup render styles
-- enh (gil) Fix effect backgrounds so that they default to first color of a gradient instead of black. Fixes #823.
-- enh (keith) Let the user turn on/off buffer and timing panel reset when changing effects. This setting is not saved when xlights is closed.
-- enh (keith) Add option to video effect to automatically synchronise with a video file that has been used for the sequence audio track.
-- enh (keith) Remove the old scheduler
-- bug (keith) Fix universe dropdown in start channel dialog did not show all universes available on an ip address if they were grouped under a single output
-- enh (keith) On value curve dialog show a tooltip when manipulating a custom curve showing the real value that will be returned by the curve at the chosen point.
-- enh (keith) Complete FPP Master mode in xScheduler
-- enh (keith) Complete FPP Remote mode in xScheduler
