smeighan
xLights release 4.2.0: Built in Papagayo
Because of the major work to get Papagayo built into xLights, I am bumping version number to 4.2.0.
This release took nearly two weeks for Dan and Gil to create.
Great job gentleman!.
If you are planning a coroface, look at Dan's video
https://youtu.be/RqYBNUdVJ3Q
If you plan on projecting images of singing faces onto your matrix, look at Gil's video
https://youtu.be/RJt22SAd-PM
4.2.0 Aug 8, 2015
-- bug(gil) Fix channel map buttons disappearing when resizing dialog. Fixes #313.
-- bug(gil) Prevent crash when doing Import Effects on xLights xml file.
-- bug(gil) Fix sparkles, brightness, and contrast text controls so that sliders update. Fixes #320.
-- bug(gil) Fix right-click crash on grid when no sequence is loaded. Fixes #317.
-- bug(dkulp) Audio at non-full speed stops too early when only playing a range
-- enh(dkulp) Add a "Minimal Grid" option for model group to specify just the area of the given models
-- enh(dkulp) Add ability to have model sizes scaled separately for horizontal and vertical directions
-- enh(gil) Add ability to import lyrics to a timing track.
4.2.0 Aug 8, 2015
