smeighan
xLights Release 4.2.4
This release sees the LAYOUT pop up error fixed
The channel overlap is now a checkbox, if there was any feeling of slowness doing the check, you can now turn it off
Selecting a model used to cause some flashing, now fixed.
Even CaptMurdoch got in this release. He fixed teh export of FPP eseq Effects files
Gil and Dan fixed some more under the cover stuff.
4.2.4 Aug 26, 2015
-- bug(gil) Fix view combo drop-down not populating when no fseq file existed. Moved Initialize call
to make sure SequenceData object has been initialized first.
-- bug(gil) Models that are renamed or deleted will now be updated in all views.
-- bug (chrisD) Fixed popup error box when selecting models in LAYOUT
-- enh(chrisD) New checkbox for channel overlap check in LAYOUT.
-- enh(chrisD) in LAYOUT fixed flashing when selecting models
-- bug(gil) Presets will now populate correctly when switching to a new Show directory.
-- bug(gil) Presets created at top level will now show up when program is reopened.
-- bug(chrisP) Fix export of Falcon .eseq Effects files
4.2.4 Aug 26, 2015
