Release release 4.2.7
smeighan
4217 Greenfinch Dr CO 80126
This release has an enhancement to Gil's marquee effect.
Here is what Gil had posted on the xlights forum about this change:
"Ok I've got the new positioning settings done for the Marquee. Here's a sample GIF showing 4 marquee all placed on a matrix at the same time. You can see how they can now be positioned anywhere:
http://gph.is/1iphrro
One thing to note is when you get the next version it's best to go through your sequence and find any marquee effects and click on them and hit Update so it will store the new defaults. Otherwise what I see happens is if you make position changes on a marquee and then start clicking on other ones that were created before these new options existed the program copies the settings from the last one you worked on."
4.2.7 Sep 06, 2015
-- enh(gil) Stop effect playback when performing a Save operation.
-- enh(gil) Add scale and position options to the Marquee effect.
