OK. I have Xschedule but have not looked into it. Is is simple to use. Do i need to transfer saved sequences over to Xschedule to use repeat function. Yes i am wanting the sequence to continually play. Thanks
everything you need to know about xschedule from the guy that wrote it:
it's very simple to use for simple shows, just make sure its opening the same directory where your sequences are. also make sure xlights does NOT have lights on when using xschedule
