XerxesDGreat
- Dec 26, 2020
I'm manually adding a timing track (several tempo changes in the song) by creating an empty timing track and tapping 't' at each beat or bar (depending on which I'm working on), but I notice that they're always at least one frame (25ms) and usually two frames (50ms) after the corresponding peak in the waveform. When I add an effect, say a simple on, to a beat or bar, the models turn on/off perfectly in sync with the music, leading me to believe that the rendered waveform itself is just offset. Is there a way to refresh the waveform or move it?
