dmoore
Ok...In my never ending quest to squash every last bug in my display I was trying to figure out why 504 of my vertical pixels in my display on universe 5 stopped working. At first I though it was something with the TP3244, so I pulled it and put in a spare unit - still nothing. So I pulled both the spare and the "production" TP3244 and put them into my test rig which is a little 2ft strip of 6803. I then used the TP3244 test output to confirm that both of them were working properly. So then I though... wiring or maybe power supply. So, I pulled out the power supply and replaced it with the one used in the bench testing - no go still. Then I tried using the same setup but with the test strip (outside on the display) - no go still. Then I though... must be LSP. So I go inside, stop the show and pull up the TP3244 test program and attempt to test output on universe 5 (slave 5) with my bench test rig and it didn't work. Then I'm thinking, the TP3244 program must really only output to universe 1 even though it says it outputs to universe 1-16. Then after some more testing I discover something I had seen in the past - where my slaves in the ECG show as --INACTIVE--. Hmm...
So, I think the problem must be with the ECG, so I shot this video to show what I was seeing so everyone can see that I'm not completely crazy! Wondering if anyone else has seen these --INACTIVE-- or some other disabling of slave outputs. The ECG8 is running 1.3.1 if that helps.
Video:
ECG Configuration Issues
Video:
