Answered [SOLVED] First Pixel is solid BLUE on each port? Need help
Soggy Sanga
I recently put my pigtails onto my falcon controller F16v5. But my lights to function correctly. At all tbh. I previously had flat wire pigtails and everything worked fine. Since I swapped, nothing works at all. Video link
The first pixel on port 1 is blue.
The first pixel on port 2 is blue. Both come on at power on and stay on until power down. Both strings don't respond to anything including test.
View: https://youtube.com/shorts/nrAzN2m1X9c?feature=shared
Video
What is happening?
I would check your wiring in the controller is correct...it looks like port 1 and 2 are wired incorrectly in the controller....Looking at it face on ...far right should be V+(Brown) next one to its direct left should be Data (Yellow) and miss one to the left and the last hole should be V-(ground) it looks like you have the Data (Yellow) in the ground position in the controller....By looking at other ports it looks like you have the Blue (V-) in the wrong spot on all ports..?? Yellow Data Blue =Ground Brown =V+
Yup, operator error, wired it all wrong. Time to rewire. Small inconvenience. Thanks everyone for the assistance.
  • Like
Reactions: AAH
