MSL
- Apr 4, 2011
Hi All,
I need so help on some strobes that I cannot get to work correctly.
I built 90 strobes. After I built the strobes I programmed each one. I had a few that did not program and I found bridges that I fixed. 2 of the 90 I could not get to work.
I soldered the (three) wires (5v, ground, trigger) onto the 88 that worked. I tested each strobe after I soldered on the wires. 6 of the 88 boards do not work at all. Two others start to strobe after I apply the 5v and ground (no trigger).
I re-programmed the 6 that do not work at all and now get the following error:
“Programming...
The following memory regions failed to program correctly:
Program Memory
Address: 00000000 Expected Value: 00000025 Received Value: 00000000
Programming failed”
I looked the boards over. I cannot see any bridges.
I do not see any bridges on any of the boards.
Any ideas would be helpful.
Mark
“Programming...
Program Memory
Programming failed”
Mark
