aarondhess
- Mar 20, 2026
I've been running an F-prop successfully until a couple days ago.
What’s happening:
I recently upgraded to build 18, wonder if that's causing all the problems...
What’s happening:
- The controller loads the FSEQ file successfully
- Logs show the sequence is recognized and stored in flash
- However, output behavior is incorrect (values appear to be changing unexpectedly / not matching intended static output)
- MY LIGHTS DONT TURN ON
- Configuration initially reported as invalid (“Invalid end token”)
- After reloading, config appears to load from SD → flash
- Logs show values being modified even when they should remain static
- Channels per Pixel: 2 (when my config was set at 3)
- String 1 Pixels: 0 (when my config was set to 180)
- Brightness: 16 (when I was at 255)
- I loaded an empty sd card and my entire strip lit up with the on-board default config (rainbow with a vibration trigger to shif to to white), so my strip and the f-prop are functional
- I created a basic config with the online programming tool, I told it to run 20 pixels on white. Everything loaded, I got the steady blinking LED indicator light on the board, nothing turned on. I checked the log and it had set my pixel counts to zero.
- I've given up trying to run my own xlights fseq. I can't even get the basics to work anymore!
