The test pattern is stuck - ISSUE SOLVED
Imacericg
[SIZE=78%]Its stuck on the test pattern - all of the dip switches are down, and I have reset it several times. The lights never go off, once it boots up, it goes right into the test pattern[/SIZE]
Re: Not Impressed with P12R: The test pattern is stuck & 10.10.10.10 hangs IE
Within the firmware settings down the bottom of the IP config page there will be a check box with 'test pat' and 'E1.31 enabled'
Make sure the E1.31 enabled box is checked and that the test pattern check box is unchecked, you should then be good.
YES!! that did it. Thank you!!
