smeighan
REMEMBER! Do a "File,Backup" before installing a new xLights.
3.6.5 Nov 20, 2014
-enh (sean) New effect class , Strobe.
-enh (sean) Icons on top of each effect improved. This icons will be what you drag and drop effects in xLights 4.0. This early introduction
is to help familiarize users with the icons to an effect.
-bug (frankr) Non music sequences would freeze preview play. fixed
-enh (djulien) Add Papagayo option for scaled vs. fixed picture mode
-enh (djulien) Allow Papagayo grid row labels to be aliased (click on row label to change it); cosmetic only - does not change xml file
-bug (djulien) Avoid "error 0" after writing new Papagayo file
-bug (dkulp) SingleLine models with multiple string bug one node per string were displayed as a single light
-bug (dkulp) Rotating single lines would cause the number of lights to display to drop by 2. (lose the ends)
-enh (dkulp) Added pixel level "Skips" effect to SingleStrand effects.
-enh (dkulp) Add ability to shift columns in the grid left or right to reorder them.
-enh (dkulp) If the effect is NONE and the buffer is already clear, skip clearing it. For large Whole House models, clearing the
buffer can take time so skip it if we can.
-bug (dkulp) If the preview is too large for the viewport such that part of the preview was cut off
at the top, clicking wasn't adjusting the Y coordinate to compensate when determining what
was being clicked on.
When: thurs, Nov 20th. 7pm MST, 9pm EST
We will be using teamviewer. Ill start session at 6:45pm MST
Please join the meeting, by clicking on this link:
http://go.teamviewer.com/v9/m93271823
Meeting ID: m93-271-823
If you have a microphone, click on the "Voice over IP" on the Teamviewer menu and unmute your headphone to be able to ask questions.
3.6.5 Nov 20, 2014
