Upgrade Oddity with channel allocation
Hoogieburner2
I just upgraded my Pi from 5.xx to 7.5 (fpp)
the only thing changed is instead of using route tables ive utilized the proxy tables in the fpp.
Completed a test sequence and the lights are all over the place....looking at the channels from xlights to fpp to f16v3 they just dont line up.
I am sure this is something simple i am over looking and i likely left this too close to the Big Day coming up but i am pulling m hair out as to what this is.
Anybody have some insight on this?
Thanks!
Have you done an FPP Connect with UDP Out set to all, to upload the configuration to FPP, as well as Upload Outputs to the controller?
You are a magician......thank you sir....i knew it had to be something simple!
now i can dedicate my time to sequences instead of new plugs for the hair ive pulled out.
Appreciated.
