Use Color Palettes to get more out of your Nutcracker effects
smeighan
4217 Greenfinch Dr CO 80126
One thing we might miss in using xlights is the judicious use of color palettes. You can have unlimited palettes, 6 colors per.
edit the palette. You can save the current palette and give it a name, you load a palette from a saved name.
you can have unlimited palettes.
Have one dim colors
one bright
one palette that are blues, greens.
you then load a palette to use. Every effect can have a different palette.
The only thing you cant do is change the palette mid stream in an effect. You cant start spirals with one palette and end with a different one.
Effect 1 and 2 have their own set of palettes. All of this palette info is stored in your sequence xml.
try some of these
http://www.tigercolor.com/color-lab/color-theory/color-theory-intro.htm
and then use this free tool that uses this theory
http://www.sessions.edu/color-calculator
Thanks Sean. I use the colour palettes a far bit but didn't realise I could save them. Thanks. I had also been wondering about the science behind colour patterns and selecting combinations that look good. Will use those tools from now on too.
Was struggling with that the other day, guess I still haven't seen the save spot! I just kept entering the same values every time I changed elements and effects, eventually I got all of them the same, but being able to save and load them would have saved me quite a bit of effort!
Alan
