janastas
- Nov 30, 2020
Morning all,
I just wanted to confirm the following wiriring won't cause me any issues.
The long story short is I have an LRS-350-5v dc power supply where I'm already utilising the other two positive / negative terminals for other devices and I only have one positive / negative terminal left.
I want to hookup two devices (Kulp K40 board and also a falcon differential receiver) to this terminal and wanted to use wago lever nuts to do this.
See the diagram below, just wanted to check what I'm doing is correct.
Pretty much there will be one cable coming out of the positive terminal with an inline fuse to the first wago lever nut, then one wire going to the K40 and the other one to the differential receiver.
Same thing for the negative terminal but no line fuse going to the second wago lever nut, then out ot each devices negative terminal.
