buzzdude
Hi
I'm struggling to create 3 window frames in xlights. Well just one would be a start.
I have a 10m strip light (100 nodes) = 300 channels. This strip will fit perfectly within the window Top/bottom 2.8m and sides are 2.2.
I cannot seem to get the configuration in xlights to give me 300 Channels
To test i tried to make a perfect square, I enter
Nodes Top 25
left/right 25
Bottom 25, but this show in xlights as 75 Channels. The node layout shows a perfect square with all 100 nodes in use. And this works in the preview, but does not seem to makes sense in configuring the channels within the controller/strip.
If anyone has worked it out could you let me know.
Xlights version i was using 3.2.2, upgraded to 3.2.3 but same issue occurs.
Shane
Nodes Top 25
left/right 25
Shane
