Release x;ights release 4.0.14.
smeighan
4217 Greenfinch Dr CO 80126
xLights release 4.0.14
Gil has added the equivalent of xltap. While playing a song, press "t". timing marks will be added to your active timing track.
Gil has made it so when you create a new sequence, there always will be a blank timing track.
Dan has added shortcut keys so you can drop effects without having to drop the, This means you have two ways to insert an effect
into the sequencer area. Only the "ON" effect is bound with this release.
4.0.14 Apr 4, 2015
-- enh (dkulp) New keys bound as short-cuts for dropping effects. Do this instead of dragging effects.
-- enh (gil) Allow timings to be added while model playback is paused. This is like xltap. Press play and use the "t" key to create timing marks
-- bug (gil) Disallow effect play while paused in model playback.
-- enh (gil) Add an empty timing track to a new sequence by default.
-- enh (gil) Ability to add timing marks while sequence is playing
-- bug (gil) Dropping or Control-V pasting into an empty area with a partial effect consumes the effect #160
-- enh (gil) When dragging effects, do not require timing track to be active #143
This is really starting to get ready for you all to start sequencing your shows.
Because this was a very content rich release I have made a tutorial.
https://vimeo.com/124120611
gil jones
dan kulp
sean
