smeighan
This release is from Dan Kulp. He found an issue importing in large LOR files.
If you use LOR you probably want this release.
When importing large lms files (like 1gbyte in size) , it appeared as if xlights was stuck. In fact it was working.
Dan has added feedback to the import process so you know its working.
RELEASE NOTES
3.4.2
-Bug fix (dkulp) Problems loading large LMS files causing crashes/hangs
-Enh (dkulp) Add additional status messages while loading LMS files
find the latest code here http://nutcracker123.com/nutcracker/releases/
Again, thanks dkulp!!
sean
RELEASE NOTES
3.4.2
sean
