smeighan
Release 3.6.15
http://nutcracker123.com/nutcracker/releases/
Be sure to do a "File,Backup" before installing any new software
3.6.15 Dec 25, 2014
-enh (dkulp) Modify F3 so that effects like morph can try to work.
-enh (djulien) Allow option to continue Preview playback if channel data is missing from .xseq file (helps avoid the need to re-render everything if you've added props at the end)
-enh (djulien) Default Brightness to 100% if setting not present in XML file (only affects externally generated XML files)
-enh (djulien) show elapsed time on file loads
-bug (djulien) Fixed Wave effect when rendered in a .xseq (FillColor was not selected, which resulted in no output)
3.6.15 Dec 25, 2014
