smeighan
xlights 4.2.1 released
4.2.1 Aug 14, 2015
-- enh(gil) Timings added to a sequence default to exist in all views.
-- bug(gil) Mark rgbeffects file as changed when views are modified.
-- bug(dkulp) Fix saving the model XML during resize/rotate
-- bug(dkulp) Fix clearing when an effect is shrunk
-- bug(dkulp) If a papagayo track is in the sequence, trying to add another timing track will crash
-- enh(gil) Models that are copied will now display in the center of the screen.
-- enh(dkulp) Add ability to enable/disable various outputs (so if controllers aren't hooked up, don't arp flood)
-- enh(dkulp) Add ability to configure e1.31 ouput to handle consecutive universes in one output
-- bug(dkulp) Fix problem of rotating elements with unequal scales
4.2.1 Aug 14, 2015
