smeighan
Remember ; do a "File,Backup" before installing. Always save copies of your xml files.
Release notes for 3.2.2:
- Enhancement: (Dan) When importing hlsIdata, sort by the universes number to make the import predictable and repeatable.
- Enhancement: (Dan) When importing hlsIdata, change the file extension for the Audio from PCM to mp3.
- Bug: (Dan) If there is a named test setup, much of the functionality on the Setup tab (up/down arrows, modifying a network, etc..) did not work properly and could result in modifying the wrong network. Fixed.
- Bug: (Dan) Preview/Nutcracker tab drawing on the Mac would result in "ghosts" of the flashing lights due to anti-aliasing. Fixed.
- Bug: (Dan) At certain screen sizes, some pixels in mega-trees and other Nutcracker models may not display. Fixed.
As you can see Dan Kulp was the major contributor for this release.
thanks
sean
thanks
sean
