xlights/nutcracker 3.2.7 released.
smeighan
4217 Greenfinch Dr CO 80126
ver 3.2.7 is released
This content is brough to you by Frankr. Thanks Frank!
Up until this release when you click export , every channel in your SETUP tab will be exported. Sometimes you might want to make a megatree or arch in nutcracker and just bring that into your sequencer. Frank has added the ability to export only the channels associated with a model.
Second item is this release; Frank has fixed the channels that were wrong on a window model.
sean,frank
3.2.7: - Bug (frankr) Windows model displayed wrong channel counts.
- Enhancement (frankr) You can now export just one model instead of every channel that is in your setup
1st method: "export" This does not look at models and instead exports every channel that has been defined
in your setup Tab
2nd method (new): "Export Model". You now can pick the model that is attached to your sequence and only export
those channels. For example, I have megatree, arches, eaves. If I select megatree only the channels
associated to that model will be exported. This will make much, much smaller LOR lms,lcb or vixen vix,vir files.
3.2.6: - Bug (Sean) Removed Linus and Lucy mp3 file from songs directory, we don't distribute mp3's
- Enhancement (Frankr and djulien). New hot keys created.
F3 Toggles between PLAY/STOP for far left "Play Effect" button
F4 Toggles between PLAY/STOP for top "Play" button
F3 -- will start to play an effect (left play) if none is playing and no sequence is playing
if an effect is playing it will stop playing. if a sequence is playing it will
stop playing and the current effect will play. This allows for easy editing of an effect.
F4 -- Starts playing a sequence (top play) from the current selected cell
If a sequence is playing it will be stopped.
F5 Same as clicking the "Update Grid" button
Ctl-o Same as clicking the open button
Ctl-s save as clicking the save file button
