smeighan
xLights 2017.17 released.Latest releases are found at www.xlights.org
2017.17 Jun 19, 2017
-- bug (gil) Fix individual start channels not displaying correct numbers.
-- enh (gil) Use freeform selection if selected timing track has no timing marks.
-- bug (gil) Prevent overlaps of Spiral and Fan effects imported from SuperStar.
-- bug (keith) Fix issue highlighted in this thread http://nutcracker123.com/forum/index.php?topic=4407.0
-- bug (keith) Fix back to back glediator effects not rendering correctly.
2017.16 Jun 13, 2017
-- bug (dkulp) Fix some resize issues in import dialog
-- bug (dkulp) Fix drag/drop in import dialog (requires rebuild of wxWidgets)
-- bug (dkulp) Fix sorting in available models on import dialog
-- bug (gil) Correct 3D DMX model rotating opposite of other view types.
-- bug (gil) Fix crash when deleting last view in the list. Fixes #869.
-- enh (gil) Add ability to right-click House Preview and switch to custom previews you've created.
-- enh (gil) Bars Effect: add new directions and VC to center point to allow precise motions.
-- bug (gil) Fix effect preset import bug that caused old effect upgrade code to run. Fixes #863.
-- enh (keith) Get Pixlite 4 controller upload working
-- enh (keith) Get J1Sys P2 controller upload working
-- enh (keith) Show models already used in mapping dialog
-- enh (keith) Add more submodel generation options
-- enh (keith) Add auto mapping for xlights/lor/vixen import ... automatically maps identical model/group names
-- bug (keith) Force model start channels to be up to date if accessing functions from setup tab
-- enh (keith) Add Model State to DMX model so you can use them to represent DMX channels where specific values
represent specific behaviour
-- bug (keith) Force new models/groups to appear immediately in sequence elements available list for master view
-- bug (keith) Prevent xlights import overwriting existing effects
-- bug (keith) Fix if no effects present render never ends
