smeighan
xLights release 2017.22
With this release we go back to BETA quality. BETA means we do not expect any new crashes and all of your sequences work as before.
The previous two releases were marked as ALPHA as we were releasing many changes for AC sequencing.
2017.22 Aug 06, 2017
-- bug (gil) Fix timeline display for sequences greater than an hour. Fixes #811.
-- bug (dan) Prevent a GIF with 0 frame time hanging xlights
-- enh (keith) Test tab auto turn on
-- bug (keith) Fix on exit test tab doesnt turn back on output to lights correctly
-- enh (keith) Test tab remembers test settings between sessions
-- bug (keith) Fix change name of model causes loss of model selection
-- enh (keith) Improve model naming when copying or adding new models
-- bug (keith) Fix cascade again ... it will work someday
-- bug (keith) Fix failed backup in some subfolders
-- enh (keith) Add remove unused layers to row heading right click menu
-- bug (keith) Prevent errors pasting models with illegal data
-- bug (keith) Fix backup not working for directories with . in the name
-- bug (keith) Fix AC cascade ... again
-- enh (keith) Add controller and connection details to node layout
-- enh (keith) Add ability to create a custom model from an inbuilt model
-- bug (keith) Fix string count on export models csv ... make it our best guess at the number of physical light strings
-- enh (keith) Make model group panel drag and drop
