Release xLights release: 2026.13
Status
Not open for further replies.
dkulp
Framingham, MA
2026.13 — July 14, 2026​
Enhancements​
  • charlie — Effect Symbols: define a reusable effect once and link any number of effects to it; editing one propagates to all linked effects. Symbols round-trip through .xsq with a "Convert All Symbols to Effects" escape hatch for compatibility export (#2671)
  • scott — Windows: experimental Vulkan preview rendering backend (model preview, sequencer grid, waveform, color canvases), switchable via Preferences > Other > "Preview graphics"; defaults to OpenGL with automatic fallback
  • dan — Linux: Vulkan preview rendering backend with X11 and native Wayland surface support; new "Auto" default picks Vulkan only when OpenGL would fall back to software rendering (llvmpipe)
  • dkulp — Linux/Windows: GPU-accelerated rendering (Vulkan) for blur, rotozoom, transitions, layer blending and most effects, mirroring the Metal backend on macOS; enable via Preferences > Other > GPU rendering
  • dkulp — macOS/iPad: Shader effect now renders natively on Metal (GLSL translated to Metal via SPIR-V and cached); set XL_NO_NATIVE_SHADER=1 to force the OpenGL fallback
  • dkulp/scott — Linux/Windows: Shader effect now renders natively on Vulkan (GLSL -> SPIR-V via glslang); falls back to OpenGL when Vulkan is unavailable
  • dkulp — GPU/SIMD rendering for additional effects: Tree, Shimmer, Candle (per-node), Wave, Garlands, Fill, Life, Twinkle, and Meteors
  • dkulp — Galaxy effect: faster per-pixel rendering method (ISPC/Metal/Vulkan)
  • dkulp — Galaxy effect: blend passes now scan only the bounding box instead of the whole buffer, up to ~5x faster on large 2D models
  • dkulp — Much faster saving of large .fseq files via multi-threaded zstd compression
  • dkulp — Add headless render mode (--headless -s <seq.xsq>): renders sequences to .fseq with no window, then exits
  • cybercop23 — Effect Presets track unsaved changes independently; preset-only edits no longer mark the RGB effects file dirty
  • alex — Tools - Test: defer controller connection until a model/port is selected, eliminating startup delay; re-resolve hostnames on demand for controllers that were offline at startup
  • daryl — Recall the last directory used in Open Sequence and Save Sequence As dialogs (#3107)
Bug Fixes​
  • daryl — Undo of a Model Set move now restores every member of the Set, not just the grabbed prop (#6681)
  • daryl — Mark the layout as needing a save when aliases are added
  • charlie — Fix app hang when changing a color to a gradient/color curve on an effect linked to an Effect Symbol (deadlock in symbol propagation)
  • daryl — Fix Align To Closest Timing Mark doing nothing when both ends of an effect are closest to the same mark (#6659)
  • daryl — Fix Align To Closest Timing Mark creating impossible effect overlaps (#6652)
  • cybercop23 — Fix crash configuring a 3D Servo model when servo count is increased (#6663)
  • cybercop23 — Fix "Copy Layers/SubModels to Models" for submodels with trailing empty layers (#6647)
  • dkulp — Fix crash cancelling or failing a model download/import with a malformed .xmodel (double-free)
  • dkulp — Fix crash in 3D layout preview after deleting a model (stale cached model list)
  • dkulp — Fix crash closing the Key Bindings editor with an uncommitted property edit
  • dkulp — Fix crash clicking "Render All" while a sequence is closing
  • dkulp — macOS: fix crash after deleting a model while a property-grid combo popup is being torn down (wxWidgets fork fix)
  • dkulp — Metal: fix crash when the GPU refuses a texture allocation (memory pressure or zero-sized image)
  • dkulp — Windows: fix crash rendering Shader effects after a GPU device reset (WDDM TDR)
  • dkulp — Linux: fix random startup crash from Moving Head panel adding its Color page to a notebook twice (use-after-free)
  • dkulp — Fix non-deterministic Meteors effect rendering (threading race in overlapping trails)
  • dkulp — macOS GPU: fix layer blending ignoring CPU-computed transition masks, causing wrong/non-deterministic transitions
  • dkulp — Fix non-deterministic rendering with "Per Model" buffer style (race reading effect settings during parallel member renders)
  • dkulp — Fix non-deterministic rendering of groups containing a nested group plus its own members (race on shared channels)
  • dkulp — Fix "Random" value/color curves re-randomizing on every render instead of producing stable results
  • dkulp — macOS GPU: fix non-deterministic Blur output (replaced MPS tent filter with deterministic compute kernel)
  • dkulp — macOS GPU: fix RotoZoom X/Y rotate writing past buffer bounds into adjacent layers, causing run-to-run corruption
  • dkulp — macOS: fix Video effect occasionally dropping frames or choosing different frames per render; playback is now frame-exact
  • dkulp — macOS GPU: fix non-deterministic Canvas layer output when group nodes share a buffer pixel
  • dkulp — macOS GPU: fix non-deterministic Rotate/Zoom output when multiple source pixels map to the same destination
  • dkulp — Fix non-deterministic Twinkle effect when twinkling by node on groups with shared buffer pixels
  • dkulp — Fix non-deterministic Kaleidoscope effect (Square/Triangle) rendering
  • dkulp — Fix headless render not honoring the "Use GPU For Rendering" preference
  • dkulp — Fix Galaxy effect rendering extremely slowly on very wide/short buffers (e.g. "Single Line" render style)
Changes​
  • dkulp — Render jobs now suspend and reschedule instead of blocking threads, reducing the thread pool to roughly CPU+GPU core count and lowering memory use on large sequences
xLights is available for download from https://github.com/xLightsSequencer/xLights/releases/ for Windows/Linux and from the App Store for Mac.
For requests for general help among peers, consider starting a new forum thread: https://auschristmaslighting.com/forums/xlights-xschedule.61/post-thread
Status
