smeighan
RELEASE 4.0.9 for xLights
This release will make it so that you can move models up and down in your SEQUENCER tab
There are also bug fixes
4.0.9 Mar 31, 2015
-- bug (gil) Move multiple elements at once using Render Position (move up/move down) in Sequence Elements Frame #114
-- bug (dpitts) modified move model up and down in the Sequence Elements screen to keep the moving model in the screen
-- bug () Fade across timing marks not working correctly #56
-- bug () Tabs can be moved (like moving frames from the Sequence tab around) #57
-- bug () Changing default perspective causes uncaptured crash on exit #64
-- bug () dragging the main window larger (repeat of closed #69) #70
-- bug () 4.0.6 Hard Crash on opening subsequent sequence #110 (Just a retest to make sure still good)
4.0.8 Mar 28, 2015
Gil Jones has been busy on this Saturday, Mar 28th
-- bug (gil) Error message when audio file missing #116
-- bug (gil) Drawing and selection issues in EffectsGrid #115
-- bug (gil) Purple effect highlight in grid is not moving with the mouse click to next effect. #113
-- bug (sean) Title bar says 4.0.67 versus 4.0.7 #112
-- bug (gil) 4.0.6 File, New sequence does not scrub screen from previous sequence #111
-- bug (gil) 4.0.6 Hard Crash on opening subsequent sequence #110
-- bug (gil) Can't cancel New Sequence #76
-- bug (gil) Ability to close the current open sequence #37
-- bug (gil) Dragging selection of effects similar to #59 #79
-- enh (sean) Created "House Preview" icon to be used on tool bar. This will cycle display on/off
4.0.7 Mar 27, 2015
-- enh (dkulp) Whole House Preview is now part of SEQUENCER tab. This was a major code rewrite!
-- bug (gil) Unable to delete models from the Sequence Element Screen #101
-- bug (gil) Timing insert when near an endpoint causes overlapping timings. #100
-- bug (gil) Adding and deleting models #54
-- bug (gil) Waveform showing as black window #58
To see latest releases: http://nutcracker123.com/nutcracker/releases/
To find MAC releases: http://dankulp.com/xlights/?C=M;O=D
To get more info on the issues listed: https://github.com/smeighan/xLights/issues
4.0.9 Mar 31, 2015
4.0.8 Mar 28, 2015
4.0.7 Mar 27, 2015
