xLights ver 3.6.10. Mostly bug fixes.
smeighan
4217 Greenfinch Dr CO 80126
3.6.10 Dec 3, 2014
-bug (sean) Added missing xLights.ico file. You should see icon in tray now
-bug (sean) "Create Random Effects"Would create None,None about 20% of time. This is now fixed.
-bug (sean) Ripple was not rendering to PREVIEW screen or to actual lights. fixed
-bug (dkulp) If "Save" is clicked multiple times real quick, it could hang/crash as it tries to save/render things at the same time.
Fixed by disabling the Save buttons while saving.
-bug (dkulp) Insert row inserting two rows, not one
-bug (dkulp) On the MAC, the clipboard sometimes used \r instead of \n.
(From Numbers for example) Update the paste to the grid to accommodate that.
-enh (dkulp) Change the "Play (F4)" button in the NUTCRACKER tab to be a Play/Stop toggle.
can you post a 10 second video that has the issue.
I will convert it to 200 png files and then try it.
I think it was frankr who changed the playback. This was because he wanted to have voice synced playback of videos.
btw, you may need the "-r 20"option
The -r says to resample your movie into 20 fps.
I dont believe the speed slider now can change the playback speed.
