- Thread starter
- #1
Last year I ordered 300m of RGB rope light from ATG Electronics in China. These operate on 110vdc with positive neutral. I ordered 512 DMX controllers from ATG which I control with LOR and iDMX1000 converter. If you check my video you can see these ropes on all my eves plus 6 big palm trees wrapped at front of house. I had serious problem with blues failing on the tree wraps. Out of 110m, I had 55m of lights that failed the blue sections. ATG was fair and sent me 110m of new ropes to replace the failed units. The ropes mounted on eves had no failures. The failures took place on the wrapping only. Needless to say I won't be wrapping any more trees with these rope lights. I now have 55m of rope with no blue but red and green is still usuable. I have tried to control these ropes with LOR by changing 110vac to 110vdc with full wave rectifier. However it did not work out because LOR controls with positive output and and negative common. I had a cross feed problem that would control 2 colors OK but when I tried 3rd color, the first 2 colors came on also. I then tried relays which I could control by LOR but I could not fade or ramp with this setup. My question is this! Do you know of a circuit that I could use to operate these 2 colors from LOR using rectifier to convert output to dc without cross feed problem?
WaterBill
WaterBill
