1152 Node Matrix
vk3heg
Ballarat
Hi Guys,
I have a 1152 node matrix, and Pixlite 16Mk2 controller.
As the limit of nodes is 1020 per port, how do I set the matrix in xlights to span more than one port?
Stephen
Split your Matrix across a couple of ports
You can do this in xLights
I have this smaller matrix divided up over 3 outputs (not the most efficient use of controller outputs).
and then use the xLights upload to controller option to push the configuration to your controller.
How do I do that? As at the moment xlilghts is spreading it over 7 ports of 96 pixels each, and not letting me move the layout.
I have managed to get this fixed.
Strings: 2
Nodes/String: 576
Strands/String: 12
I have a1440 pixel matrix with 720 on 2 ports ill probably get told i should not do it but hey it works.
The visualizer was showing the matrix taking up 7 ports. Now it's on port 5 and 6. The real test will be when I hook the lights up. :unsure:
