2 fpp running together
bpratt
Jimboomba, Queensland
I'm trying to run my main show fpp player for my main show, but I've set up fpp on another pi which has a a rpi-28d+ on it to run my 2 x 500 pixel wings here.
What I am wanting to do is run a sequence on that pi, but only to those wings alone, but what is currently happening is that the sequence on the wing pi is not being output to the wings.
When the main fpp that is running my main show stops pumping out data to my other props, this one starts to output to the pixel wings.
Hopefully it'll be an easy fix. :)
Quite simple as I found out in the Zoom room.
on the main show player, go in to input/output setup, then channel outputs.
unselect the fpp that you want to run separately and save.
In Xlights, under controller tab, select the controller, then change Active to xlights only.
hope this will help someone else out.
