raymondclow
- Nov 25, 2021
First of all thank you if you are reading this post which i hope is in the right place, i looked around and wasn't sure where to ask for the help. I am using a Flacon f16v3, I just built 2 arches using a tutorial I found which turned out fine with the exception of one arch not lighting up at all. I am using ws2811 light strips which I cut in half to be able to make 2 arches. I am using one port on the falcon with a PSU just for the arches since i have other things running off the other PSU. I am stumped at after setting everything up only one arch lights up but the last 3 nodes are off...i checked voltage and its running through, the other arch that it's hooked up to wont light up at all....I am not sure if at this point it's wiring or setup at the falcon board? I am trying to troubleshoot but i want to know if anyone has had any issues with this before. This is my first time using pixel strips. thanks again for the help.
