Release 2015.08 Released
Status
Not open for further replies.
keithsw1111
Kellyville, NSW
2025.08 August 8, 2025
– enh (derwin12) Allow preview edits in 3D mode
– enh (derwin12) Store/restore the last directory used for imports
– enh (derwin12) Add right click option to remove “-shimmer”
– enh (scott) Add serial upload for Sandevice v5 controllers
– enh (TheHodge) Add Baldrick17 controller
– enh (scott) Add YPS VIVID8 controller
– enh (dkulp) Add K16/K16-Pro KulpLights controllers
– enh (dkulp) FPP9 – Support up to 5 matrices
– enh (derwin12) Distinguish between unsupported and unavailable for FPP connect status
– enh (keith) Support creation of submodels from states and faces
– enh (dkulp) Speed up FPP Connect discovery and initial dialog setup
– bug (derwin12) Disallow invalid characters (ex
for controller names
– bug (dkulp) Fix proxy support for ESPixelStick uploads
– bug (derwin12) Fix crash importing some models that have numbers in the middle of submodel names
– bug (derwin12) ImageEffect – images with alpha channel may display wrong
– bug (scott) Fix HinksPix universe packing issues in some setups
– bug (derwin12) Fix some issues with “Match Size” not actually matching the size for some models
– bug (derwin12) Fix check for xbkp files and properly prompt to restore
– bug (mpierreb/derwin12) Fix some issues moving effects up/down in the grid
– bug (derwin12) Fix removing of temp files after opening xsqz files
– bug (dkulp) Fix infrequent crash caused by bg ping threads when changing show dir or closing xLights
Status
