2016.25 Released. Fix for Radeon graphic cards.
Discussion in 'xLights (Nutcracker)' started by smeighan, May 6, 2016.
  1. smeighan
    smeighan Dedicated Elf
    Jan 19, 2012
    1,094
    30
    4217 Greenfinch Dr CO 80126
    Release 2016.25
    Dan hopefully fixed radeon graphic card displays
    Keith added new command "Tools, Package Problem Files". This will create a zip of your log file. You no longer need to search in the hidden folder appdata.
    2016.25 May 05, 2016
    -- bug (dkulp) Bunch more fixes to OPENGL calls. Now Radeon cards should work
    -- enh (dkulp) Add a menu item to select the max OpenGL version to use. Higher the version, the higher
    the eprformance of graphics. The lower, the more graphic cards that can be supported.
    -- enh (keithsw) New option "Tools,Log". This will create a zip file of your xlights log file. No longer need to
    search the hidden appdata directory to find it. Keith described it like this: Add "Package Problem Files"
    to tools menu which lets the user package current config/sequence/logs when reporting a problem.
    -- enh (dkulp) Sub-Buffers. Add ability to specify what section of a buffer you want the effect applied to
    -- enh (keithsw) Block manual switching between wizard tabs in auto generation of custom model.
  2. OP
    OP
    smeighan
    Jan 19, 2012
    1,094
    30
    Dan has given you the ability to pick which level of OpenGL you Want. The current software auto-detects and sets the appropriate level.
    Level 1 was released 1997,
    Level 2 released in 2004,
    Level 3 was released in 2010.
    All of these changes in the last few weeks have been to allow xLights to run at Level 3. If you have issues try reducing the level of your OpenGL libraries by using the "Settings,OpenGL".
