2016.32 Playback is now 20fps and 40fps. More improvements on OpenGL
Discussion in 'xLights (Nutcracker)' started by smeighan, May 20, 2016.
  1. smeighan
    smeighan Dedicated Elf
    Jan 19, 2012
    1,086
    21
    4217 Greenfinch Dr CO 80126
    Release 2016.32. In this release the biggest change is the playback is now 21fps and 41fps. Before it was 16fps and 30fps.
    there was nothing like a new effect, just improvements. Here is what Dan Kulp wrote:
    "There isn’t really anything “new” other than the new timer implementation. However, there are a bunch of bug fixes and optimizations and such that I’d like to get out there. This SHOULD hopefully fix the display issues on the 2.1 based Intel GPU’s, it will detect the non-accelerated GDI driver and display a message telling the user to update the video drivers, it optimizes a bunch of things on the layout panel, fixes some issues where a texture from the wrong OpenGL context could get destroyed, and bunch of defensive “null pointer” checks in a bunch of places."
    2016.32 May 19, 2016
    -- bug (dkulp) Bug where subbuffer might not get written out correctly (and written out when not needed)
    -- enh (dkulp) Optimization to not load the background image for every single mouse click on the Layout panel
    -- bug (dkulp) Use atomics instead of crit section
    -- bug (dkulp) Don't create the debug context by default anymore...
    -- bug (dkulp) Better management of TextureID's - Fixes #576
    -- bug (dkulp) Don't use the pointers for the textures
    -- bug (dkulp) Use the standard timer on OSX, it works fine and no need to have the extra thread
    -- enh (dkulp) Display a warning if GDI driver detected
    -- enh (dkulp) Add the .1 log as well just incase the rolling stuff rolled the important lines
    -- bug (dkulp) Remove some unused vars
    -- enh (dkulp) Use non-shader method for smooth points on Intel
    -- bug (dkulp) Fix setting transparency and black transparency
    -- enh (keithsw) VideoReader ... more protection for possible divide by zero errors.
    Includes logging of any problems found.
    -- bug (keithsw) Make logs 1MB as originally intended. These should zip to well under 50% when sent to us.
    -- bug (chrisD) Force TendrilEffect and TextEffect on foreground thread under Linux
