Release 2016.34 RotoZoom. value Curves. New layout in LAYOUT
smeighan
4217 Greenfinch Dr CO 80126
2016.34 released.
RotoZoom. Value Curves. New layout in LAYOUT. lots of content from Gil, Dan and Keith.
To help I made a small video showcasing some of the changes.
https://vimeo.com/168856869
Thanks xLight Developers!
sean
2016.34 May 31, 2016
-- bug (gil) Fix crash when delete key was hit in Layout with no model selected. Fixes #533.
-- enh (gil) Restructure how model groups are handled by providing a panel for them and allowing the
members of the group to be managed in the property grid area.
-- enh (gil) Add tilt parameter to the Arch model to allow better 3D perspective. Fixes #250.
-- enh (keithsw) Add starfield option to meteors implode/explode look more like a starfield
-- enh (keithsw) Add autosave to .working.xml files ... saves every 3 minutes as long as the sequence is not playing
-- enh (keithsw) Zoom and rotate added to buffer panel including value curves for most parameters
-- enh (keithsw) Blur Value Curve Added
-- bug (dkulp) DOn't corrupt rgb-effects if mouth set to (off). Fixes #577
-- bug (dkulp) Refresh the start/end channels when various properties (string type, strands, etc...) are changed. Fixes #575
